Giriş
If your wireless card needs replacement, follow the steps in this guide to remove it.
Neye ihtiyacın var
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
Bir başkası bu kılavuzu tamamladı.
