Ana içeriğe geç
Acer Aspire E5-471-5456 Ram Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-471-5456 Ram Replacement, Back Cover: adım 1, 2 resimden 1. Acer Aspire E5-471-5456 Ram Replacement, Back Cover: adım 1, 2 resimden 2.
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 Ram Replacement: adım 2, 2 resimden 1. Acer Aspire E5-471-5456 Ram Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 Ram Replacement: adım 3, 1 resimden 1.
    • Place cover and screws aside and you are now free to access the different components of this laptop.
  4. Acer Aspire E5-471-5456 Ram Replacement, RAM: adım 4, 2 resimden 1. Acer Aspire E5-471-5456 Ram Replacement, RAM: adım 4, 2 resimden 2.
    • Locate the two RAM cards.
    • Each RAM card will be held in place by two clips located on the left and right sides of each card. Simply pop both clips out at the same time and remove the RAM with your hand.
    • Repeat the process with the second RAM card.
    • Be careful when removing to avoid bumping other parts.
Sonuç
Daniel Gonzalez
364 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G4, Banghart Fall 2017 Cal Poly, Team S6-G4, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G4
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 968
