Giriş
The USB port is one of the most commonly used ports on your computer. Having a functional USB port is almost required to allow your computer to interface with other devices.The USB port may have a buildup of dust that can cause issues with connection to the port.
Neye ihtiyacın var
Carefully place the closed computer on a flat surface, with it oriented screen down.
Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
Locate the two USB ports in the bottom corner of the laptop.
Use a screwdriver to take out the M2X3 mm screw located in the orange circle. For an easier reassembly, take note that the USB port has a white arrow that indicates which orange hole the screw should be returned to.
2 farklı kişi bu kılavuzu tamamladı.
