Ana içeriğe geç
Acer Aspire E5-511p-C6US RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-511p-C6US RAM Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire E5-511p-C6US RAM Replacement, Battery: adım 1, 3 resimden 3.
    • On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
  2. Acer Aspire E5-511p-C6US RAM Replacement: adım 2, 1 resimden 1.
    • Pull battery to remove.
  3. Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: adım 3, 2 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
  4. Acer Aspire E5-511p-C6US RAM Replacement: adım 4, 2 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement: adım 4, 2 resimden 2.
    • Pull the Optical Drive out
  5. Acer Aspire E5-511p-C6US RAM Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the 17 Phillips #1 screws remaining on the back side of the laptop
  6. Acer Aspire E5-511p-C6US RAM Replacement: adım 6, 3 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement: adım 6, 3 resimden 2. Acer Aspire E5-511p-C6US RAM Replacement: adım 6, 3 resimden 3.
    • Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
  7. Acer Aspire E5-511p-C6US RAM Replacement: adım 7, 2 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement: adım 7, 2 resimden 2.
    • Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
  8. Acer Aspire E5-511p-C6US RAM Replacement, Fan: adım 8, 2 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement, Fan: adım 8, 2 resimden 2.
    • Disconnect the cord from the fan
  9. Acer Aspire E5-511p-C6US RAM Replacement: adım 9, 1 resimden 1.
    • Remove the 2 #1 Phillips screws
  10. Acer Aspire E5-511p-C6US RAM Replacement: adım 10, 1 resimden 1.
    • now the fan can be pulled from the laptop
  11. Acer Aspire E5-511p-C6US RAM Replacement, RAM: adım 11, 1 resimden 1.
    • Disconnect the 2 plugs remaining on the computer
  12. Acer Aspire E5-511p-C6US RAM Replacement: adım 12, 1 resimden 1.
    • Remove the last 2 #1 Philips screws from the body
  13. Acer Aspire E5-511p-C6US RAM Replacement: adım 13, 1 resimden 1.
    • Remove the 2 #1 Phillips screws, then slide the metal cover back and away
  14. Acer Aspire E5-511p-C6US RAM Replacement: adım 14, 1 resimden 1.
    • Remove the board from the laptop body, flip over for access to the ram
  15. Acer Aspire E5-511p-C6US RAM Replacement: adım 15, 2 resimden 1. Acer Aspire E5-511p-C6US RAM Replacement: adım 15, 2 resimden 2.
    • Press down on the spring clips on either side of the ram, It will unlock and can be removed
Sonuç
Aaron
562 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G1, Bernier Spring 2018 UMass Dartmouth, Team S2-G1, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S2G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 663
