Ana içeriğe geç
Acer Aspire E5-571 CPU Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-571 CPU Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 CPU Fan Replacement: adım 2, 1 resimden 1.
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 CPU Fan Replacement: adım 3, 1 resimden 1.
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 CPU Fan Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 CPU Fan Replacement: adım 5, 3 resimden 1. Acer Aspire E5-571 CPU Fan Replacement: adım 5, 3 resimden 2. Acer Aspire E5-571 CPU Fan Replacement: adım 5, 3 resimden 3.
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 CPU Fan Replacement: adım 6, 2 resimden 1. Acer Aspire E5-571 CPU Fan Replacement: adım 6, 2 resimden 2.
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 CPU Fan Replacement, WiFi: adım 7, 1 resimden 1.
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 CPU Fan Replacement: adım 8, 2 resimden 1. Acer Aspire E5-571 CPU Fan Replacement: adım 8, 2 resimden 2.
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 CPU Fan Replacement: adım 9, 3 resimden 1. Acer Aspire E5-571 CPU Fan Replacement: adım 9, 3 resimden 2. Acer Aspire E5-571 CPU Fan Replacement: adım 9, 3 resimden 3.
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
  10. Acer Aspire E5-571 CPU Fan Replacement, CPU Fan: adım 10, 1 resimden 1.
    • Locate the CPU Fan in the case right above the motherboard.
  11. Acer Aspire E5-571 CPU Fan Replacement: adım 11, 1 resimden 1.
    • Detach the power cable by carefully pulling on it, it will come off easily.
  12. Acer Aspire E5-571 CPU Fan Replacement: adım 12, 1 resimden 1.
    • Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
    • Now carefully lift the fan straight up and out of its place in the case.
    • The fan should easily come right out with no trouble.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
daniel sawyer
2.602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 16
Her zaman: 4,411
