Ana içeriğe geç
Acer Aspire E5-571 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: adım 2, 1 resimden 1.
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: adım 3, 1 resimden 1.
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: adım 5, 3 resimden 1. Acer Aspire E5-571 Keyboard Replacement: adım 5, 3 resimden 2. Acer Aspire E5-571 Keyboard Replacement: adım 5, 3 resimden 3.
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 Keyboard Replacement: adım 6, 2 resimden 1. Acer Aspire E5-571 Keyboard Replacement: adım 6, 2 resimden 2.
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
daniel sawyer
2.602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G2
3 Üyeler
4Kılavuz Yorumları
keyboard cable is a b$%*h
shrs - Yanıt
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Yanıt
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Yanıt
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 12,461
