Ana içeriğe geç
Acer Aspire E5-571 WiFi Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-571 WiFi Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 WiFi Replacement: adım 2, 1 resimden 1.
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 WiFi Replacement: adım 3, 1 resimden 1.
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 WiFi Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 WiFi Replacement: adım 5, 3 resimden 1. Acer Aspire E5-571 WiFi Replacement: adım 5, 3 resimden 2. Acer Aspire E5-571 WiFi Replacement: adım 5, 3 resimden 3.
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 WiFi Replacement: adım 6, 2 resimden 1. Acer Aspire E5-571 WiFi Replacement: adım 6, 2 resimden 2.
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 WiFi Replacement, WiFi: adım 7, 1 resimden 1.
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 WiFi Replacement: adım 8, 2 resimden 1. Acer Aspire E5-571 WiFi Replacement: adım 8, 2 resimden 2.
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 WiFi Replacement: adım 9, 3 resimden 1. Acer Aspire E5-571 WiFi Replacement: adım 9, 3 resimden 2. Acer Aspire E5-571 WiFi Replacement: adım 9, 3 resimden 3.
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
daniel sawyer
2.566 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G2
3 Üyeler
7 Yorum
Very well done - thank you!
glgsolutions - Yanıt
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
daniel sawyer -
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Dan O - Yanıt
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Patrizia Barberio - Yanıt
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 7,530
