Ana içeriğe geç
Acer Aspire E5-571-58CG CPU Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 2, 3 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 2, 3 resimden 2. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 2, 3 resimden 3.
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: adım 3, 3 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: adım 3, 3 resimden 2. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: adım 3, 3 resimden 3.
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 4, 2 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 4, 2 resimden 2.
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 5, 2 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 5, 2 resimden 2.
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 6, 2 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 6, 2 resimden 2.
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 7, 3 resimden 1. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 7, 3 resimden 2. Acer Aspire E5-571-58CG CPU Fan Replacement: adım 7, 3 resimden 3.
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
Sonuç
Brendan Cuthill
121 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S7G7
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 295
