Ana içeriğe geç
Acer Aspire E5-571-58CG Power Jack Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: adım 2, 3 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement: adım 2, 3 resimden 2. Acer Aspire E5-571-58CG Power Jack Replacement: adım 2, 3 resimden 3.
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: adım 3, 3 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: adım 3, 3 resimden 2. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: adım 3, 3 resimden 3.
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: adım 4, 2 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement: adım 4, 2 resimden 2.
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: adım 5, 3 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement: adım 5, 3 resimden 2. Acer Aspire E5-571-58CG Power Jack Replacement: adım 5, 3 resimden 3.
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: adım 6, 2 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement: adım 6, 2 resimden 2.
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: adım 7, 2 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement: adım 7, 2 resimden 2.
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: adım 8, 2 resimden 1. Acer Aspire E5-571-58CG Power Jack Replacement: adım 8, 2 resimden 2.
    • Carefully lift the power jack out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aliana Johnson
145 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S7G7
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,253
