Ana içeriğe geç
Acer Aspire E5-571-58CG Touchpad Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: adım 1, 3 resimden 3.
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  2. Acer Aspire E5-571-58CG Touchpad Replacement: adım 2, 3 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement: adım 2, 3 resimden 2. Acer Aspire E5-571-58CG Touchpad Replacement: adım 2, 3 resimden 3.
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  3. Acer Aspire E5-571-58CG Touchpad Replacement: adım 3, 3 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement: adım 3, 3 resimden 2. Acer Aspire E5-571-58CG Touchpad Replacement: adım 3, 3 resimden 3.
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  4. Acer Aspire E5-571-58CG Touchpad Replacement: adım 4, 3 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement: adım 4, 3 resimden 2. Acer Aspire E5-571-58CG Touchpad Replacement: adım 4, 3 resimden 3.
    • Use the metal spudger to lift the keyboard component out of the metal panel.
  5. Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: adım 5, 2 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: adım 5, 2 resimden 2.
    • Make sure you have removed the keyboard before attempting to remove the touchpad.
    • Use a 1 1/2 mm flathead screw bit to remove the black screw at the bottom of the panel.
  6. Acer Aspire E5-571-58CG Touchpad Replacement: adım 6, 3 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement: adım 6, 3 resimden 2. Acer Aspire E5-571-58CG Touchpad Replacement: adım 6, 3 resimden 3.
    • Peel back the marked strips with the metal spudger.
  7. Acer Aspire E5-571-58CG Touchpad Replacement: adım 7, 3 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement: adım 7, 3 resimden 2. Acer Aspire E5-571-58CG Touchpad Replacement: adım 7, 3 resimden 3.
    • Use a 1 1/2 mm flathead screw bit to remove the two black screws at the top of the panel.
  8. Acer Aspire E5-571-58CG Touchpad Replacement: adım 8, 2 resimden 1. Acer Aspire E5-571-58CG Touchpad Replacement: adım 8, 2 resimden 2.
    • Lift the touch pad out of the metal panel with a metal spudger.
Sonuç
Daniel Mello
258 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S7G7
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,256
