Giriş
After a while, your laptop fan could get clogged with dust and start overheating or it could get damaged due to excessive usage. Fans remove heat from the interior of the laptop. move heat away from hardware. The main objective of this is to prevent overheating, something electronics is severely sensitive with as well. This guide will help you replace your Acer Aspire E5-573G fan with easy to moderate steps that can be done at home to prevent internal damage to your hardware.
Neye ihtiyacın var
Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
Bir başkası bu kılavuzu tamamladı.
