Ana içeriğe geç
Acer Aspire E5-573G Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-573G Hard Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Hard Drive Replacement: adım 2, 1 resimden 1.
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Acer Aspire E5-573G Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Unscrew all 17 (5mm) Philips head screws from the bottom.
    • Unscrew the 3 (2.5mm) Philips head screws underneath the optical drive.
  4. Acer Aspire E5-573G Hard Drive Replacement: adım 4, 2 resimden 1. Acer Aspire E5-573G Hard Drive Replacement: adım 4, 2 resimden 2.
    • Run a pick around the edge of the laptop (between the two parts) to open it.
    • Lift the left side of the case up and unplug the speaker cable before fully taking the bottom off.
  5. Acer Aspire E5-573G Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive by pulling it out to the left.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Alex Bahm
2.241 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S12G5
2 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 50
Her zaman: 9,170
