Ana içeriğe geç
Acer Aspire E5-721-64T8 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-721-64T8 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 RAM Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 RAM Replacement: adım 3, 1 resimden 1.
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 RAM Replacement: adım 4, 2 resimden 1. Acer Aspire E5-721-64T8 RAM Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 RAM Replacement, RAM: adım 5, 2 resimden 1. Acer Aspire E5-721-64T8 RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Use your fingers to spread the metal clips on the side of the RAM apart.
    • When released, the RAM will pop up and slightly out of the socket.
    • Lift the RAM to an angle of 30 degrees and slide it out of the socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Jacobson
218 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G3, Passmore Spring 2018 USF Tampa, Team S7-G3, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 473
