Ana içeriğe geç
Acer Aspire E5-721-64T8 Touch Pad Replacement
Neye ihtiyacın var
  1. Acer Aspire E5-721-64T8 Touch Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 3, 1 resimden 1.
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 4, 2 resimden 1. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: adım 5, 2 resimden 1. Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove the two 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard.
    • Remove the four 6mm Phillips #0 screws from the heat sink.
    • Lift and remove the heatsink assembly from laptop.
  6. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 6, 1 resimden 1.
    • Remove the Wi-Fi card by pulling it from the motherboard socket.
  7. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 7, 1 resimden 1.
    • Disconnect the display cable from the motherboard.
  8. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 8, 1 resimden 1.
    • Disconnect the speaker from the motherboard.
  9. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 9, 2 resimden 1. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 9, 2 resimden 2.
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
  10. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 10, 2 resimden 1. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 10, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
  11. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
  12. Acer Aspire E5-721-64T8 Touch Pad Replacement, Touch Pad: adım 12, 1 resimden 1.
    • Peel the black adhesive film up.
  13. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 13, 1 resimden 1.
    • Remove the three 6mm Phillips #0 screws from touchpad.
  14. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 14, 1 resimden 1.
    • Use a spudger to flip up the retaining flap on the touchpad ribbon cable ZIF socket.
    • Remove the ribbon cable from the ZIF socket.
  15. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 15, 2 resimden 1. Acer Aspire E5-721-64T8 Touch Pad Replacement: adım 15, 2 resimden 2.
    • Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove.
Sonuç
Ed Herrera
390 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G3, Passmore Spring 2018 USF Tampa, Team S7-G3, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 281
