Giriş
If the laptop is failing to turn on or hold a charge, it may be because of a faulty battery. This guide will teach you how to remove and therefor replace the battery of this laptop. Be sure to disconnect the AC adapter to your laptop if it's connected before removal.
Neye ihtiyacın var
Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
Neredeyse bitti!
Sonuç
