Ana içeriğe geç
Acer Aspire ES1-111M-C7DE Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-111M-C7DE Battery Replacement, Back Cover: adım 1, 2 resimden 1. Acer Aspire ES1-111M-C7DE Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
  2. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 2, 3 resimden 1. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 2, 3 resimden 2. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 2, 3 resimden 3.
    • Using a plastic opening tool, gently pry the lower case off. Place aside.
  3. Acer Aspire ES1-111M-C7DE Battery Replacement, Battery: adım 3, 2 resimden 1. Acer Aspire ES1-111M-C7DE Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Locate the small black button surrounded by a white circle near the battery on the motherboard.
    • Press and hold the button for five seconds.
  4. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 4, 3 resimden 1. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 4, 3 resimden 2. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 4, 3 resimden 3.
    • Using your fingers or the small plastic opening tools, disconnect the battery connection from the motherboard by pinching and pulling back on both sides of the connector.
  5. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 5, 3 resimden 1. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 5, 3 resimden 2. Acer Aspire ES1-111M-C7DE Battery Replacement: adım 5, 3 resimden 3.
    • Locate the two 6.2mm black screws holding the battery in place and unscrew them.
    • Gently lift and remove the battery.
Sonuç
Reid Becker
103 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Cannon Fall 2017 USF Tampa, Team S3-G1, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 1,720
