Ana içeriğe geç
Acer Aspire ES1-111M-C7DE Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-111M-C7DE Screen Replacement, Screen: adım 1, 3 resimden 1. Acer Aspire ES1-111M-C7DE Screen Replacement, Screen: adım 1, 3 resimden 2. Acer Aspire ES1-111M-C7DE Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Open the laptop screen to the farthest back position
    • Using the plastic opening tool, pry off the screen border and completely remove it.
  2. Acer Aspire ES1-111M-C7DE Screen Replacement: adım 2, 2 resimden 1. Acer Aspire ES1-111M-C7DE Screen Replacement: adım 2, 2 resimden 2.
    • •Using the JIS #1 screwdriver, remove the 4 3mmscrews from each corner of the screen
  3. Acer Aspire ES1-111M-C7DE Screen Replacement: adım 3, 1 resimden 1.
    • Remove the screen and turn it face down
  4. Acer Aspire ES1-111M-C7DE Screen Replacement: adım 4, 2 resimden 1. Acer Aspire ES1-111M-C7DE Screen Replacement: adım 4, 2 resimden 2.
    • Carefully pull back the tape on the connector until the connector is fully revealed
  5. Acer Aspire ES1-111M-C7DE Screen Replacement: adım 5, 1 resimden 1.
    • Carefully remove the connector from the old screen and connect it to your new, compatible screen
Sonuç
To reassemble your device, follow these instructions in reverse order starting from Step 3.
2 farklı kişi bu kılavuzu tamamladı.
Timothy Carney
135 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Cannon Fall 2017 USF Tampa, Team S3-G1, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 370
