Ana içeriğe geç
Acer Aspire ES1-512-C80E Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-512-C80E Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Battery Replacement: adım 2, 3 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement: adım 2, 3 resimden 2. Acer Aspire ES1-512-C80E Battery Replacement: adım 2, 3 resimden 3.
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: adım 3, 3 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: adım 3, 3 resimden 2. Acer Aspire ES1-512-C80E Battery Replacement, Keyboard: adım 3, 3 resimden 3.
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Battery Replacement: adım 4, 3 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement: adım 4, 3 resimden 2. Acer Aspire ES1-512-C80E Battery Replacement: adım 4, 3 resimden 3.
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Battery Replacement: adım 5, 2 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement: adım 5, 2 resimden 2.
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Battery Replacement: adım 6, 1 resimden 1.
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Battery Replacement, Battery: adım 7, 3 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement, Battery: adım 7, 3 resimden 2. Acer Aspire ES1-512-C80E Battery Replacement, Battery: adım 7, 3 resimden 3.
    • Remove the two 1.2mm Phillips #00 screws securing the battery.
  8. Acer Aspire ES1-512-C80E Battery Replacement: adım 8, 3 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement: adım 8, 3 resimden 2. Acer Aspire ES1-512-C80E Battery Replacement: adım 8, 3 resimden 3.
    • Use a nylon spudger to remove the battery from the clips that hold it down.
  9. Acer Aspire ES1-512-C80E Battery Replacement: adım 9, 3 resimden 1. Acer Aspire ES1-512-C80E Battery Replacement: adım 9, 3 resimden 2. Acer Aspire ES1-512-C80E Battery Replacement: adım 9, 3 resimden 3.
    • Remove the wired connection to the laptop by pulling the plug out of the motherboard.
    • Remove the battery from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robert Creighton
686 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G8
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 37
Her zaman: 2,194
