Ana içeriğe geç
Acer Aspire ES1-512-C80E Disk Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 2, 3 resimden 1. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 2, 3 resimden 2. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 2, 3 resimden 3.
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: adım 3, 3 resimden 1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: adım 3, 3 resimden 2. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: adım 3, 3 resimden 3.
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 4, 3 resimden 1. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 4, 3 resimden 2. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 4, 3 resimden 3.
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 5, 2 resimden 1. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 5, 2 resimden 2.
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Disk Drive Replacement: adım 6, 1 resimden 1.
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: adım 7, 3 resimden 1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: adım 7, 3 resimden 2. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: adım 7, 3 resimden 3.
    • Push the disk drive out of the side slot.
Sonuç
To reassemble your device, follow the steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
Peter Bulman
231 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G8
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 497
