Giriş
You may need to replace the keyboard on your Acer Aspire ES1-512-C80E if you experience problems regarding the device’s input. To access the keyboard, the back cover of the device will need to be removed. The process of replacing the keyboard should take between 15-25 minutes.
Neye ihtiyacın var
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
2 farklı kişi bu kılavuzu tamamladı.
