Ana içeriğe geç
Acer Aspire ES1-512-C80E RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-512-C80E RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E RAM Replacement: adım 2, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 2, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement: adım 2, 3 resimden 3.
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E RAM Replacement, Keyboard: adım 3, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement, Keyboard: adım 3, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement, Keyboard: adım 3, 3 resimden 3.
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E RAM Replacement: adım 4, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 4, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement: adım 4, 3 resimden 3.
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E RAM Replacement: adım 5, 2 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 5, 2 resimden 2.
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E RAM Replacement: adım 6, 1 resimden 1.
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E RAM Replacement, Removing Hard Drive screws: adım 7, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement, Removing Hard Drive screws: adım 7, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement, Removing Hard Drive screws: adım 7, 3 resimden 3.
    • Using a Phillips #000 screwdriver, remove the five 1.2mm screws that hold the hard drive in place.
    • Attention Only the screw on the opposite end of the port of the hard drive needs to be removed. Then the hard drive will slide away from the Motherboard while still in the plastic case. Once slid out all the way, it lifts out separately with ease.
  8. Acer Aspire ES1-512-C80E RAM Replacement: adım 8, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 8, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement: adım 8, 3 resimden 3.
    • Lift the hard drive, fan, motherboard, and wireless LAN card out of the device.
    • These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
  9. Acer Aspire ES1-512-C80E RAM Replacement, Removing Drive: adım 9, 2 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement, Removing Drive: adım 9, 2 resimden 2.
    • Once the four components are out of the device, the hard drive is ready to be removed.
    • To remove the hard drive, unplug it from the motherboard.
    • Attention The hard drive does not lift out of the computer CONNECTED to the motherboard. It can damage connection of hard drive on motherboard. Once the Screw on the opposite end of the port is removed, the Hard Drive should slide away from the Motherboard and lift out with ease.
  10. Acer Aspire ES1-512-C80E RAM Replacement, RAM: adım 10, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement, RAM: adım 10, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement, RAM: adım 10, 3 resimden 3.
    • Flip over the motherboard.
    • Remove all three 1.2mm screws that attach the fan to the motherboard using a Phillips #00 screwdriver.
    • Lift the fan off of the motherboard.
    • The fan and the motherboard are still connected with wires. Remove any plugs that may be attaching the components.
  11. Acer Aspire ES1-512-C80E RAM Replacement: adım 11, 2 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 11, 2 resimden 2.
    • Remove the wireless LAN card from the motherboard by unplugging the connecting wires.
  12. Acer Aspire ES1-512-C80E RAM Replacement: adım 12, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 12, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement: adım 12, 3 resimden 3.
    • Gently remove the tape and plug from the motherboard.
  13. Acer Aspire ES1-512-C80E RAM Replacement: adım 13, 3 resimden 1. Acer Aspire ES1-512-C80E RAM Replacement: adım 13, 3 resimden 2. Acer Aspire ES1-512-C80E RAM Replacement: adım 13, 3 resimden 3.
    • In order to remove the RAM, push both of the clips outward and the RAM chip will easily slide up and out.
  14. Acer Aspire ES1-512-C80E RAM Replacement: adım 14, 1 resimden 1.
    • The RAM is removed and ready to be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Creighton
682 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G8
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 23
Her zaman: 1,009
