Ana içeriğe geç
Acer Aspire ES1-512-C96S Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-512-C96S Battery Replacement, Removing the Screws and Opening it Up: adım 1, 3 resimden 1. Acer Aspire ES1-512-C96S Battery Replacement, Removing the Screws and Opening it Up: adım 1, 3 resimden 2. Acer Aspire ES1-512-C96S Battery Replacement, Removing the Screws and Opening it Up: adım 1, 3 resimden 3.
    • Place the device upside down on a flat, soft surface.
    • Using a Phillips #0 screwdriver, remove all 18 screws that secure the bottom cover of the device.
    • Once all screws are removed, flip laptop back over and open it.
    • Begin prying in the corners and use a spluger to pry around the edge. Hearing popping noises from the plastic is normal.
  2. Acer Aspire ES1-512-C96S Battery Replacement, Lifting Keyboard: adım 2, 2 resimden 1. Acer Aspire ES1-512-C96S Battery Replacement, Lifting Keyboard: adım 2, 2 resimden 2.
    • Lift Slowly, once you have popped all the plastic off the bottom case. Do not lift off completely
    • There are 2 ribbon cables are connecting the keyboard and Touch pad to the Motherboard.
  3. Acer Aspire ES1-512-C96S Battery Replacement, Disconnecting Keyboard and Touchpad Cables: adım 3, 3 resimden 1. Acer Aspire ES1-512-C96S Battery Replacement, Disconnecting Keyboard and Touchpad Cables: adım 3, 3 resimden 2. Acer Aspire ES1-512-C96S Battery Replacement, Disconnecting Keyboard and Touchpad Cables: adım 3, 3 resimden 3.
    • Locate the lock for the larger Ribbon cable on the sides of the cable. Slide them back, Gently, until they release the cable. The lock may fall off, that's okay. It will reattach.
    • Notice the lock bar is off of the connector.
    • The smaller ribbon cable has a latch, that is pulled upward, gently, until it disengages.
    • Now the Keyboard should remove completely.
  4. Acer Aspire ES1-512-C96S Battery Replacement, Removing Battery from locks: adım 4, 3 resimden 1. Acer Aspire ES1-512-C96S Battery Replacement, Removing Battery from locks: adım 4, 3 resimden 2. Acer Aspire ES1-512-C96S Battery Replacement, Removing Battery from locks: adım 4, 3 resimden 3.
    • Disconnect the Battery from the Motherboard and there is 1 screw, PH0, that is holding the battery in place.
    • There are also several tabs that are holding the battery in place. Bend the tabs down slightly, just enough to disengage them.
    • Once all locking tabs have been moved, lift from bottom and pull out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 283
