Giriş
This guide contains instructions on removing the battery from your Acer Aspire ES1-711-P1UV. If your battery is faulty, it may result in your computer not turning on or randomly turning off during use. By replacing the battery, these issues should be resolved.
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
4 farklı kişi bu kılavuzu tamamladı.
2 Comments
Excellent instructions, Thxz.
