Ana içeriğe geç
Giriş
This guide provides instructions on removing the hard drive from your Acer Aspire ES1-711-p1UV laptop. You may need to follow this guide if your laptop is having troubles loading multiple pages or tabs, or is low on memory. If these issues are occuring, you may need to replace your hard drive to install new memory.
Parçalar
Hiçbir parça belirtilmedi.
  1. Place the laptop face down on a flat, clean surface.
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Use the iFixit opening tool to pry open the four corners of the back cover of the laptop.  You may need to use your hands to fully remove the cover.
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Remove the two 5 mm screws located on either side of the battery.
    • Remove the two 5 mm screws located on either side of the battery.
  5. Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  6. Remove the four 4.5 mm screws that hold the hard drive in place.
    • Remove the four 4.5 mm screws that hold the hard drive in place.
  7. Remove the tabs holding the hard drive in place. Remove the hard drive.
    • Remove the tabs holding the hard drive in place.
    • Remove the hard drive.
Sonuç
Lindsay O'Shea
304 İtibar
3 adet Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 9
Son 30 Gün: 35
Her zaman: 358
