Ana içeriğe geç
Acer Aspire ES1-711-P1UV RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire ES1-711-P1UV RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV RAM Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV RAM Replacement: adım 3, 1 resimden 1.
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV RAM Replacement: adım 4, 1 resimden 1.
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV RAM Replacement, RAM: adım 5, 3 resimden 1. Acer Aspire ES1-711-P1UV RAM Replacement, RAM: adım 5, 3 resimden 2. Acer Aspire ES1-711-P1UV RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Locate RAM and push metal clips outwards to release RAM. The RAM will eject at a 30 degree angle.
    • Slide the RAM out of the clips to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Camille Ingham
418 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,112
