Ana içeriğe geç
Acer Aspire M5-583P-6423 RAM Memory Stick Replacement
Neye ihtiyacın var
  1. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
    • Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement: adım 2, 2 resimden 1. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement: adım 2, 2 resimden 2.
    • Push the back cover up from each side using the iFixit opening tool.
    • You’ll hear a popping sound as you lift the back cover.
    • Once the back cover is separated, you’ll see all the internal components of the laptop.
  3. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement: adım 3, 2 resimden 1. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement: adım 3, 2 resimden 2.
    • Pull the rainbow cord out by using the iFixit opening tool on each side of its connecting slot.
    • This step can be done by using your fingers, but its highly recommended to use the iFixit removal tool instead.
  4. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement: adım 4, 1 resimden 1.
    • Remove the M2.5 x 3mm screw that holds down the battery using the Phillips #00 screwdriver.
  5. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement: adım 5, 1 resimden 1.
    • Lift the battery up from its edges and pull back slightly towards the hinges to remove the battery.
    • The battery is now detached from the laptop and can be set aside.
  6. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement, RAM Memory stick: adım 6, 3 resimden 1. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement, RAM Memory stick: adım 6, 3 resimden 2. Acer Aspire M5-583P-6423 RAM Memory Stick Replacement, RAM Memory stick: adım 6, 3 resimden 3.
    • This is where your laptop's RAM memory stick is located in the motherboard.
    • There are two (2) side clips securing the existing RAM memory stick on your laptop.
    • Pull the side clips away from the existing RAM memory stick in the direction marked by the arrows. This will unlock the RAM memory stick.
    • Slide the RAM stick out from the slot.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 578
