Giriş
This guide will explain how to safely remove the Acer Aspire M5-583P-6423 mSATA Solid-State Drive in order to replace it. To avoid harming any components, you’ll need the iFixit opening tool and a Phillips #00 screwdriver. The steps are not difficult, but it’s important to follow all of them as they are mentioned.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
The boxed area shows where your mSATA Solid State Drive (mSATA SSD) connects to your laptop's motherboard.
Remove the M2x3mm screw using the Phillips #00 Screwdriver.
If your laptop already has an mSATA SSD connected, remove it by lifting it up to a 45° angle and pulling it out.
Bir başkası bu kılavuzu tamamladı.
