Ana içeriğe geç
Acer Aspire M5-583P-9688 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire M5-583P-9688 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Acer Aspire M5-583P-9688 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Aspire M5-583P-9688 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire M5-583P-9688 Hard Drive Replacement: adım 3, 2 resimden 2.
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Collin Steel
328 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,628
