Ana içeriğe geç
Acer Aspire One 532h-2527 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 2, 1 resimden 1.
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 3, 1 resimden 1.
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 4, 3 resimden 1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 4, 3 resimden 2. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 4, 3 resimden 3.
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Back Plate: adım 5, 1 resimden 1.
    • Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
  6. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool on the recessed notch at the bottom of the larger plate to gently lift the plate.
  7. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 7, 1 resimden 1.
    • Once the plate becomes unhinged, gently rotate the plate to take it off of the device.
  8. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Hard Disk Drive: adım 8, 1 resimden 1.
    • Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
  9. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 9, 2 resimden 1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 9, 2 resimden 2.
    • Gently press down on the HDD and slide it to the left as far as it will go.
  10. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 10, 2 resimden 1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: adım 10, 2 resimden 2.
    • Grab the edges of the HDD, slightly rotate it, and gently pull it out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Erica Romero
481 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G6
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 1,659
