Ana içeriğe geç
Acer Aspire One 722 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire One 722 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Screen Replacement: adım 2, 1 resimden 1.
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Screen Replacement: adım 3, 1 resimden 1.
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Screen Replacement: adım 4, 2 resimden 1. Acer Aspire One 722 Screen Replacement: adım 4, 2 resimden 2.
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Screen Replacement: adım 5, 1 resimden 1.
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Screen Replacement, Screen: adım 6, 2 resimden 1. Acer Aspire One 722 Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Remove the black rubber clips from the bottom right and left of the netbook screen.
  7. Acer Aspire One 722 Screen Replacement: adım 7, 2 resimden 1. Acer Aspire One 722 Screen Replacement: adım 7, 2 resimden 2.
    • Remove the screws under the black caps.
  8. Acer Aspire One 722 Screen Replacement: adım 8, 3 resimden 1. Acer Aspire One 722 Screen Replacement: adım 8, 3 resimden 2. Acer Aspire One 722 Screen Replacement: adım 8, 3 resimden 3.
    • Slowly separate the screen casing from the screen.
    • Potential for device damage: Be careful when detaching the screen casing from the screen. If not done slowly, it can break.
  9. Acer Aspire One 722 Screen Replacement: adım 9, 3 resimden 1. Acer Aspire One 722 Screen Replacement: adım 9, 3 resimden 2. Acer Aspire One 722 Screen Replacement: adım 9, 3 resimden 3.
    • Remove the screws located on the four corners of the screen.
  10. Acer Aspire One 722 Screen Replacement: adım 10, 3 resimden 1. Acer Aspire One 722 Screen Replacement: adım 10, 3 resimden 2. Acer Aspire One 722 Screen Replacement: adım 10, 3 resimden 3.
    • Remove the two bottom screws.
    • Taking out these screws will allow you to remove the screen from its attachment.
  11. Acer Aspire One 722 Screen Replacement: adım 11, 3 resimden 1. Acer Aspire One 722 Screen Replacement: adım 11, 3 resimden 2. Acer Aspire One 722 Screen Replacement: adım 11, 3 resimden 3.
    • On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
  12. Acer Aspire One 722 Screen Replacement: adım 12, 3 resimden 1. Acer Aspire One 722 Screen Replacement: adım 12, 3 resimden 2. Acer Aspire One 722 Screen Replacement: adım 12, 3 resimden 3.
    • On the green board, remove the two screws.
    • Remove the board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Christian Barboza
818 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 3,302
