Ana içeriğe geç
Acer Aspire One 725-0845 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire One 725-0845 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 RAM Replacement: adım 2, 3 resimden 1. Acer Aspire One 725-0845 RAM Replacement: adım 2, 3 resimden 2. Acer Aspire One 725-0845 RAM Replacement: adım 2, 3 resimden 3.
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 RAM Replacement, Back Plate: adım 3, 3 resimden 1. Acer Aspire One 725-0845 RAM Replacement, Back Plate: adım 3, 3 resimden 2. Acer Aspire One 725-0845 RAM Replacement, Back Plate: adım 3, 3 resimden 3.
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 RAM Replacement, RAM: adım 4, 3 resimden 1. Acer Aspire One 725-0845 RAM Replacement, RAM: adım 4, 3 resimden 2. Acer Aspire One 725-0845 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Using two fingers, push the clamps away from the RAM chip, releasing it from the motherboard.
    • Carefully remove the RAM chip by pulling it out and away from the center of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Allen
134 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-3, Eyestone Spring 2017 USF Tampa, Team 8-3, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G3
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 515
