Ana içeriğe geç
Acer Aspire One 751h-1948 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire One 751h-1948 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Close the laptop and flip it over to view the back of the laptop.
  2. Acer Aspire One 751h-1948 Keyboard Replacement: adım 2, 3 resimden 1. Acer Aspire One 751h-1948 Keyboard Replacement: adım 2, 3 resimden 2. Acer Aspire One 751h-1948 Keyboard Replacement: adım 2, 3 resimden 3.
    • Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
  3. Acer Aspire One 751h-1948 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Acer Aspire One 751h-1948 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Acer Aspire One 751h-1948 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
    • Don't lift the keyboard completely so that you don't damage the ribbon cable underneath.
  4. Acer Aspire One 751h-1948 Keyboard Replacement: adım 4, 2 resimden 1. Acer Aspire One 751h-1948 Keyboard Replacement: adım 4, 2 resimden 2.
    • When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
    • Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Bolton
434 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G2, Catania Spring 2017 UMass Dartmouth, Team S8-G2, Catania Spring 2017 üyesi
UMASSD-CATANIA-S17S8G2
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 258
