Ana içeriğe geç
Acer Aspire One A150-1570 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: adım 2, 2 resimden 1. Acer Aspire One A150-1570 Keyboard Replacement: adım 2, 2 resimden 2.
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: adım 3, 2 resimden 1. Acer Aspire One A150-1570 Keyboard Replacement: adım 3, 2 resimden 2.
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: adım 4, 3 resimden 1. Acer Aspire One A150-1570 Keyboard Replacement: adım 4, 3 resimden 2. Acer Aspire One A150-1570 Keyboard Replacement: adım 4, 3 resimden 3.
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: adım 5, 3 resimden 1. Acer Aspire One A150-1570 Keyboard Replacement: adım 5, 3 resimden 2. Acer Aspire One A150-1570 Keyboard Replacement: adım 5, 3 resimden 3.
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Blue
124 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 410
