Ana içeriğe geç
Acer Aspire One A150-1570 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire One A150-1570 Motherboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Motherboard Replacement: adım 2, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 2, 2 resimden 2.
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Motherboard Replacement: adım 3, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 3, 2 resimden 2.
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Motherboard Replacement: adım 4, 3 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 4, 3 resimden 2. Acer Aspire One A150-1570 Motherboard Replacement: adım 4, 3 resimden 3.
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Motherboard Replacement: adım 5, 3 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 5, 3 resimden 2. Acer Aspire One A150-1570 Motherboard Replacement: adım 5, 3 resimden 3.
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
  6. Acer Aspire One A150-1570 Motherboard Replacement, Internal Wireless Card: adım 6, 1 resimden 1.
    • Close and flip the device over so you can have a good view of all the screws.
    • Locate and remove the three 3.9mm screws where the battery was removed from.
    • Locate and and remove the two 5.8mm screws located underneath the bumpers.
    • Locate and remove the three 5.8mm remaining screws at the top of the device.
  7. Acer Aspire One A150-1570 Motherboard Replacement: adım 7, 3 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 7, 3 resimden 2. Acer Aspire One A150-1570 Motherboard Replacement: adım 7, 3 resimden 3.
    • Flip and reopen device to where you can view the internal panel.
    • Locate the ZIF connecting the mouse panel to the motherboard.
    • Flip up the black plastic hinge and carefully pull out the ZIF connector.
  8. Acer Aspire One A150-1570 Motherboard Replacement: adım 8, 1 resimden 1.
    • Locate and remove all five 4.7mm black screws.
    • Locate and remove the one 4.3mm silver screw.
  9. Acer Aspire One A150-1570 Motherboard Replacement: adım 9, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 9, 2 resimden 2.
    • Pick a corner and slowly lift up the panel while running your finger underneath to pop off the seals.
    • Make sure to move slowly. You do not want to crack the plastic from being to rough or moving to fast.
  10. Acer Aspire One A150-1570 Motherboard Replacement: adım 10, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 10, 2 resimden 2.
    • Locate the internal wireless card.
    • Remove the one 3.9mm screw holding it down.
  11. Acer Aspire One A150-1570 Motherboard Replacement: adım 11, 3 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 11, 3 resimden 2. Acer Aspire One A150-1570 Motherboard Replacement: adım 11, 3 resimden 3.
    • Carefully disconnect the black and white cable from the internal wireless card.
    • Pull the internal wireless card straight out.
  12. Acer Aspire One A150-1570 Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Locate and remove the four 3.9mm screws on the right side of your device.
  13. Acer Aspire One A150-1570 Motherboard Replacement: adım 13, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 13, 2 resimden 2.
    • Locate the display cable in the upper left corner of your device.
    • Carefully disconnect the display cable.
  14. Acer Aspire One A150-1570 Motherboard Replacement: adım 14, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 14, 2 resimden 2.
    • Locate the speaker cable at the bottom of the mother board.
    • Carefully pull the cable to disconnect the speaker from the mother board.
  15. Acer Aspire One A150-1570 Motherboard Replacement: adım 15, 2 resimden 1. Acer Aspire One A150-1570 Motherboard Replacement: adım 15, 2 resimden 2.
    • Locate and remove the last two remaining 4.7mm screws in the upper left corner of the motherboard.
    • Gently lift the motherboard off the device frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Briana Naranjo
369 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 1,173
