Ana içeriğe geç
Acer Aspire One AO756-2623 Back Cover Replacement
Neye ihtiyacın var
  1. Acer Aspire One AO756-2623 Back Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Back Cover Replacement: adım 2, 1 resimden 1.
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Back Cover Replacement: adım 3, 3 resimden 1. Acer Aspire One AO756-2623 Back Cover Replacement: adım 3, 3 resimden 2. Acer Aspire One AO756-2623 Back Cover Replacement: adım 3, 3 resimden 3.
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Back Cover Replacement, Back Cover: adım 4, 1 resimden 1.
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Back Cover Replacement: adım 5, 2 resimden 1. Acer Aspire One AO756-2623 Back Cover Replacement: adım 5, 2 resimden 2.
    • Slide the back plate downward to remove it from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Colin Rodwell
382 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G1
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,871
