Giriş
The removal of the back cover is necessary to be able to replace any other parts of the laptop. The removal is a two step process which involves removing the battery and one screw.
Neye ihtiyacın var
Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
Locate the single 6 mm Phillips screw in the lower middle of the back plate.
Remove the screw using a Phillips #0 Screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
