Ana içeriğe geç
Acer Aspire One AO756-2623 LCD Sceen Replacement
Neye ihtiyacın var
  1. Acer Aspire One AO756-2623 LCD Sceen Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 2, 1 resimden 1.
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 3, 3 resimden 1. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 3, 3 resimden 2. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 3, 3 resimden 3.
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 LCD Sceen Replacement, LCD Sceen: adım 4, 1 resimden 1.
    • Orient the laptop as shown in the picture with the open screen facing toward you.
  5. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 5, 3 resimden 1. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 5, 3 resimden 2. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 5, 3 resimden 3.
    • Insert the spudger into the indicated crease.
    • Firmly slide spudger around the edge of the entire laptop to remove the front plate of the screen.
    • Loud cracking noises from the plastic tabs separating may occur, do not worry, they are to be expected.
  6. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 6, 3 resimden 1. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 6, 3 resimden 2. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 6, 3 resimden 3.
    • Identify the four 6 mm Phillips screws that are necessary to remove the LCD screen.
    • Remove all four screws using a Phillips #0 Screwdriver.
    • Pull away the LCD screen from the back cover of the laptop without ripping the ribbon cable connecting it to the bottom of the laptop.
  7. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 7, 3 resimden 1. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 7, 3 resimden 2. Acer Aspire One AO756-2623 LCD Sceen Replacement: adım 7, 3 resimden 3.
    • Remove the tape covering the port connecting the screen to the bottom of the laptop.
    • To remove the LCD screen, gently pull the cable straight out of the screen.
    • In the first and second photos, the screen is lying face down on the keyboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Davis Adams
465 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G1
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Spot on! Perfect tutorial thank-you very much!
Sonia Green - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 1,037
