Ana içeriğe geç
Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement
Neye ihtiyacın var
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: adım 1, 3 resimden 1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: adım 1, 3 resimden 2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 2, 2 resimden 1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 2, 2 resimden 2.
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 3, 3 resimden 1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 3, 3 resimden 2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 3, 3 resimden 3.
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 4, 2 resimden 1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 4, 2 resimden 2.
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 5, 2 resimden 1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: adım 5, 2 resimden 2.
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Hasenbein
119 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G4, Bruce Fall 2017 CSU Fullerton, Team S1-G4, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,040
