Giriş
If the life of your battery is significantly shortened, it may be damaged or old. This guide can help you replace the battery by yourself!
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Power the laptop off.
Flip the laptop over and position it so the opening faces you.
Remove the rubber foot located near the opening side of the device using tweezers.
Flip the back panel so the battery faces down.
Remove the rubber foot with tweezers.
Bir başkası bu kılavuzu tamamladı.
