Ana içeriğe geç
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 2, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Battery: adım 3, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 4, 3 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 4, 3 resimden 2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 5, 3 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 5, 3 resimden 2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: adım 5, 3 resimden 3.
    • Disconnect the battery from the motherboard.
    • Remove the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joseph
685 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G1, Passmore Spring 2018 USF Tampa, Team S20-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 2,940
