Ana içeriğe geç
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
Neye ihtiyacın var
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 2, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: adım 3, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 4, 3 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 4, 3 resimden 2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 4, 3 resimden 3.
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 5, 3 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 5, 3 resimden 2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 5, 3 resimden 3.
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: adım 6, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: adım 6, 2 resimden 2.
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 7, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 7, 2 resimden 2.
    • Disconnect the two antenna cables from the Wi-fi card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 8, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 8, 2 resimden 2.
    • Disconnect the display cable by pulling it down and towards you.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 9, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 9, 2 resimden 2.
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: adım 10, 1 resimden 1.
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joseph
685 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G1, Passmore Spring 2018 USF Tampa, Team S20-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,611
