Ana içeriğe geç
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement
Neye ihtiyacın var
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement: adım 2, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement, Wifi Card: adım 3, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement, Wifi Card: adım 3, 2 resimden 2.
    • Disconnect the two antenna cables from the Wi-Fi card.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement: adım 4, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement: adım 4, 2 resimden 2.
    • Remove the single 5mm Phillips #0 screw from the Wi-Fi card.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement: adım 5, 2 resimden 1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Wifi Card Replacement: adım 5, 2 resimden 2.
    • Slide out the Wifi card from its slot by pulling parallel to the board.
Sonuç
Joseph
685 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G1, Passmore Spring 2018 USF Tampa, Team S20-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,057
