Ana içeriğe geç
Acer Aspire One D150 Memory Upgrade Replacement
Neye ihtiyacın var
  1. Acer Aspire One D150 Memory Upgrade Replacement, Memory Upgrade: adım 1, 1 resimden 1.
    • Be sure computer is unplugged, turned off, and battery is removed.
    • Then, locate memory door and remove screw with #0 Phillips screw driver.
  2. Acer Aspire One D150 Memory Upgrade Replacement: adım 2, 1 resimden 1.
    • If needed, pry open door using knife or flat screw driver.
  3. Acer Aspire One D150 Memory Upgrade Replacement: adım 3, 3 resimden 1. Acer Aspire One D150 Memory Upgrade Replacement: adım 3, 3 resimden 2. Acer Aspire One D150 Memory Upgrade Replacement: adım 3, 3 resimden 3.
    • Remove plastic door to expose lone memory DIMM.
    • Press two metal clasps on both sides of the DIMM apart to allow memory module to pop up.
  4. Acer Aspire One D150 Memory Upgrade Replacement: adım 4, 1 resimden 1.
    • Head over to Newegg and buy yourself a 2gb DDR2, 667mhz laptop memory to install in your Aspire One.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Dante Bertana
702 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 21,379
