Ana içeriğe geç
Acer Aspire One D225-1625 Wireless Card Replacement
Neye ihtiyacın var
  1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire One D225-1625 Wireless Card Replacement, Battery: adım 1, 3 resimden 3.
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D225-1625 Wireless Card Replacement: adım 2, 1 resimden 1.
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 1. Acer Aspire One D225-1625 Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 2.
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel and slide back and forth across the edge until the back gently pops off.
  4. Acer Aspire One D225-1625 Wireless Card Replacement: adım 4, 2 resimden 1. Acer Aspire One D225-1625 Wireless Card Replacement: adım 4, 2 resimden 2.
    • Use tweezers to disconnect the black and white wires from the wireless card by pulling them up off the card.
  5. Acer Aspire One D225-1625 Wireless Card Replacement: adım 5, 2 resimden 1. Acer Aspire One D225-1625 Wireless Card Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to unscrew the top right screw on the wireless card.
    • Pull out wireless card by sliding it out to your right.
Sonuç
Bir Yorum
Awesome I changed wireless card with your instruction this is a helpful 👍👍
sohil shekh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 416
