Ana içeriğe geç
Acer Aspire One D255E Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: adım 2, 2 resimden 1. Acer Aspire One D255E Keyboard Replacement: adım 2, 2 resimden 2.
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: adım 3, 3 resimden 1. Acer Aspire One D255E Keyboard Replacement: adım 3, 3 resimden 2. Acer Aspire One D255E Keyboard Replacement: adım 3, 3 resimden 3.
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: adım 4, 1 resimden 1.
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian
1.248 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S16G8
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 2,366
