Ana içeriğe geç
Acer Aspire One D255E Keyboard Replacement
Görüntüleme: 3,2 B
İstatistikleri görüntüle:
Son 24 Saat:
6
Son 7 Gün:
30
Son 30 Gün:
88
Her zaman:
3.189
Yorumlar: 1
1 comment on steps.
Tamamlandı: 3
3 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 2
2 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: Tahmin yok
Zorluk: Orta
The keyboard is the most essential input component on a laptop. Though this component is designed to have frequent usage either with old age or bad treatment this component may have to be replaced. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
Neye ihtiyacın var
Aletler
  • Spudger
    4.9
    1. Acer Aspire One D255E Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Start by removing the battery found on the back of the device.
      • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
      FixBot'a Sor
      Yorum Ekle
    2. Acer Aspire One D255E Keyboard Replacement: adım 2, 2 resimden 1. Acer Aspire One D255E Keyboard Replacement: adım 2, 2 resimden 2.
      • Using plastic opening tools press down the 6 clips located around the keyboard.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Aspire One D255E Keyboard Replacement: adım 3, 3 resimden 1. Acer Aspire One D255E Keyboard Replacement: adım 3, 3 resimden 2. Acer Aspire One D255E Keyboard Replacement: adım 3, 3 resimden 3.
      • Using a plastic opening tool or spudger move the keyboard out of position.
      • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
      • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Aspire One D255E Keyboard Replacement: adım 4, 1 resimden 1.
      • Using a spudger gently push the tab on the port forward then pull out the cable.
      • Be careful to do so as gently as possible. You do not want to damage the port.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Yazar
ile
Brian
1.329 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S16G8
2 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 30
Son 30 gün: 88
Her zaman: 3,189
