Ana içeriğe geç
Acer Aspire One D255E Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire One D255E Screen Replacement, Screen: adım 1, 2 resimden 1. Acer Aspire One D255E Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Using a spudger remove the two screw covers on the front of the computer.
  2. Acer Aspire One D255E Screen Replacement: adım 2, 2 resimden 1. Acer Aspire One D255E Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
  3. Acer Aspire One D255E Screen Replacement: adım 3, 1 resimden 1.
    • Using a spudger for assistance remove the front panel of the screen.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Screen Replacement: adım 4, 3 resimden 1. Acer Aspire One D255E Screen Replacement: adım 4, 3 resimden 2. Acer Aspire One D255E Screen Replacement: adım 4, 3 resimden 3.
    • Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
    • There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
  5. Acer Aspire One D255E Screen Replacement: adım 5, 1 resimden 1.
    • Carefully remove the display ribbon cable from the connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian
1.248 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S16G8
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 2,122
