Ana içeriğe geç
Acer Aspire One D255E Screen Replacement
Neye ihtiyacın var
    1. Acer Aspire One D255E Screen Replacement, Screen: adım 1, 2 resimden 1. Acer Aspire One D255E Screen Replacement, Screen: adım 1, 2 resimden 2.
      • Using a spudger remove the two screw covers on the front of the computer.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Aspire One D255E Screen Replacement: adım 2, 2 resimden 1. Acer Aspire One D255E Screen Replacement: adım 2, 2 resimden 2.
      • Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Aspire One D255E Screen Replacement: adım 3, 1 resimden 1.
      • Using a spudger for assistance remove the front panel of the screen.
      • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
      FixBot'a Sor
      Yorum Ekle
    4. Acer Aspire One D255E Screen Replacement: adım 4, 3 resimden 1. Acer Aspire One D255E Screen Replacement: adım 4, 3 resimden 2. Acer Aspire One D255E Screen Replacement: adım 4, 3 resimden 3.
      • Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
      • There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
      FixBot'a Sor
      Yorum Ekle
    5. Acer Aspire One D255E Screen Replacement: adım 5, 1 resimden 1.
      • Carefully remove the display ribbon cable from the connector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brian
1.329 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S16G8
2 Üyeler
59 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 2,788
