Giriş
Describes how to remove the keyboard.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
5 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
