Ana içeriğe geç
Acer Aspire One D270-1865 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire One D270-1865 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Acer Aspire One D270-1865 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Acer Aspire One D270-1865 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Put on an anti-static wrist band, attaching the end onto a large piece of metal.
    • Make sure the laptop is unplugged from its charging cord.
    • Flip the laptop over to view the underside.
    • Slide the right battery lock/unlock button to unlock, sliding the tab outward to unlock.
    • At the same time, slide the left tab outwards while placing thumb on the grip strips of the battery and pull the battery outwards until it slides out.
  2. Acer Aspire One D270-1865 Keyboard Replacement, Keyboard: adım 2, 2 resimden 1. Acer Aspire One D270-1865 Keyboard Replacement, Keyboard: adım 2, 2 resimden 2.
    • Flip the device right-side up.
    • Open device.
    • Insert the plastic opening tool above the F8 key.
    • Do not damage the F8 key.
    • Gently pop off the keyboard by pulling up and towards you.
  3. Acer Aspire One D270-1865 Keyboard Replacement: adım 3, 2 resimden 1. Acer Aspire One D270-1865 Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the keyboard ribbon attached to the bottom of the keyboard by pulling it forward.
    • Remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
I need to replace the battery. It has served me well since 2012 - it's hard letting it go..which battery replacement is best..i have replaced the keyboard once, but not satisfying
malsawmdawngliana khithie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 2,366
